XTS2500 usb programming cable
natedawg1604
Colorado
Yeah, I would stay away from aftermarket programming cables that have a USB connector on them. Better to go with the aftermarket serial cable that has the DB9 connector, then use a good quality USB to serial converter with it.
I use the same thing, an aftermarket XTS serial cable with a FTDI adapter to go from serial to USB, it's very reasonably priced. I've had zero issues. I would second/third the prior comment about using FTDI for the USB side, you also need that for older Uniden scanners. I had problems when I originally tried a dirt cheap serial to USB cable from a box store.
FFPM571
Nashvillle
I use IoGear GUC232A and an aftermarket cable. I also have a OEM XTS Cable with the RS232 non USB.. I can use the IoGear on either cable. Honestly the aftermarket seems to work better and is smaller
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
I've never had any issues with the aftermarket serial cable for the XTS(any) radios as long as I was using a USB-serial converter with an FTDI chipset. The "Prolific" chipset, not so much; there are so many cables running around out there with counterfeit Prolific chipsets in them I wouldn't trust them as far as I could throw an aircraft carrier.
Of course, straight serial works fine and dandy. Thank goodness for my trusty Toughbooks with real comm ports.
That all being said, I have an aftermarket USB cable for the APX portables which works just fine.
GTR8000
NY/NJ Database Guy
BEE00
The TrendNet USB-serial converter I use has a genuine Prolific chip and has worked fine for years, not only with my aftermarket XTS cable, but also with my 346XT using the Uniden serial cable. I have a real serial port also, but it's on the back of my PC and not as convenient as plugging the USB into a front port. 🤷‍♂️
com501
Prolific put out a driver update that is supposed to brick the counterfeit cables. I don't know how it works, but have never had my hands on a counterfeit cable, either.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
And that's one of the reasons I prefer to stick solely with FTDI devices. I know they work, and I don't have to be concerned about potential counterfeit Prolific devices (or drivers which might brick them).
Too much money invested in these radios to take a chance.
