XTS3000 Software Programming
KC9UNK
Rock Co,Wisconsin
I was wondering if you could help me,with how to set up the scan,the dual monitor but most importantly i have no idea how the access or open the remaining 32 channels,im useing the main 16 on the dial,if you could help that would really be great.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Assign a menu item for Zone or the abc switch to Zone Select.
Add in two more zones and then use the menu item or switch to select between the three zones.
KC9UNK
Rock Co,Wisconsin
zones
Okay i must not have did something right,cause i assigned 3 zones at the zone assignment at the bottom of the program menu,then i went to the channel assignment and i added all 48,then i went into the control button menu and it still doesnt allow me to activate anything to get to those other 32 channels,such as the zone select feature you mentioned with the ABC toggle?
KC9UNK
Rock Co,Wisconsin
zone
i also must not being doing something right cause under the zone assignment window,that box is darken out,so something else is also not set up right.Im so frustrated with this software that im to the point of getting rid of the radio and iv only had it for 3 weeks
KC9UNK
Rock Co,Wisconsin
zones
I think i have it figured out,thanks everybody,now my next step is to figure out the priority/dual monitor but i wont bug you guys with that..lol
