XTS5000 FPP and Regular channel programming
clanusb
Northern CA
Hello everyone. I am currently trying to set up my radio the way I want it in the CPS. I have the first 15 zones FPP enabled with 16 channels each. However I want to add several more zones of obviously non-FPP channels. The problem is that CPS is not allowing me to create any more conventional personalities beyond 255. What is it that I'm missing? CPS says the radio has a max of 1000 channels, and I know only 240 of those can be FPP, which is what I have set up. Thank you for your help!
Radio Info:
XTS5000 VHF M3
H18KEH9PW7AN
FIRMWARE: R20.00.10
DSP: R19.50.00
UCM: 505.07.15
FLASHCODE: 5A0001-000306-3
I am using the latest CPS of R20.00.10
NEPA
You don't need to create a new personality for every channel like with FPP! So you can have the same personality for all of your Non-FPP zones.
clanusb
Northern CA
Thank you...figured it had to be something that simple. So used to MTS2000's CPS where it actually was a new personality for each channel.
NEPA
No problem! I'm pretty familiar with these radios, so if you need anything else, just reply here and I'll get an email, and should be able to help you asap.
