XTS5000 PTT chirp :how to enable
VNR5338
I can't remember if there is a feature that will enable a chirp from the radio speaker when PTT. If there is,; what tab in the CPS is it hiding under?
RIVER_5
ÆS LØVER
You can set up a clear alert tone with the XTS series radio which will emit a small beep when you press the PTT as long as you don't have encryption turned on.
Setup:
Demo:
VNR5338
Setup:
Demo:
That's the feature !! Thanks for the videos. I will play with the cps tonight.
chrismol1
P25 TruCking!
I have a previous write up for it on conventional if thats what your looking for. A member had an issue with the DVRS bursts but maybe its a firmware or corrupt/whacky codeplug issue as I didn't have the problem on my end. I worked hard to figure it out
It was purely for the sake of trying to do what others said couldn't be done
