Xts5000 question
devicelab
Radio N.E.R.D
WA (USA)
yeah, complete with Chinese knock off housings, put together by our "faktory traned teknishuns" with fresh copies of depot software...I've seen a couple of these radios and I'd like to know what "in house analyzer" is...an engine analyzer maybe for a 1984 Ford Bronco?
Just FYI, I purchased a VHF unit from this guy (prior to his newest ad with the fancy colors) and after a month of testing out replacements, I still didn't have a working unit. In fairness, he tried to make it right but in the end I just had to give up and get a refund. The first unit I received would power cycle if anything metallic touched the antenna socket. Yes, it worked fine without an antenna but put the antenna on and it went nuts. If I touched the antenna socket with a screwdriver it would reset. It was possessed. :ROFLMAO:
Giddyuptd
Here and there
For giggles I went and got a couple of them faktory like new feom (fabricated oem) housings. Thre them on 2 dead rf board 2500s for giggles. Did some tests. While majority held up to normal wear extreme dropping the plastic cracked significantly. Water in standard rain was ok though submerging had issues with the plastic seating with the rubber seals internally. Some of the housings were too tight on the inner lining causing strain on the internal guts or back plate showing signs of stress on the housing sides.
For basic ham use they'd be cool. But I wouldn't depend on these for fire use or public safety.
Maybe and thats a large maybe a parks worker cleaning trash bags and bathrooms but wouldn't suggest it as anything government is considered mission critical.
On a average notice the button rubbers are too long inside and must be trimmed on some which causes buttons to easily press as well as the tightness of the internal plastic sealing against backplate. This could be issue of ptt, emergency depress when not needed.
It was a for fun deal since one of my fire fighters decided to remove a used, perfectly ok housing from a 2500 for a fancy lime green look.
After endless emergency depresses from sitting and moving around driving this resulted in questions thus dealing with that issue.
There was only 1 market I was aware of in the oem realm for impact yellow and lime green oem housings down in south America where policia federal in one particular country had contracted for a handful of lime green which wasn't many and rest impact yellow.
Anything else is that use at own risk. If it sits on a desk ok but you have question once you're gone or so and so changes hands in jobs will that unit end up in field as a loaner or stand in for someone walking into a fire?
If its at home, personal, non mission critical have at it. Government issued, owned or used on mission critical have your radio techs mainly admin end approve it. I doubt they will as I sure as hell wouldn't.
ElroyJetson
I bought a brown ("coyote tan") housing for my VHF XTS5000. It was about as described above. Not quite an exact and perfect fit in some ways. I can't install a programming cable due to slight misalignment of the molded-in slot where the locator boss on the plug fits in, but that's easily rectified with a minute with a Dremel tool and a steady hand. It works well enough. PTT actuator doesn't have much of a feel to it, it may be a bit long.
I'd agree, it's fine for casual use. I would not care to be the guy who signed off on equipping my SWAT team with them.
DeoVindice
P25 Underground
5150 Level
That's unfortunate, the aftermarket housings look neat but that sounds like about all they're good for.
prcguy
I bought and installed several aftermarket cases for the XTS2500 series and they are just fine. Can't really tell the difference from original except for the color. There is more than one company making them and I bought mine from an Ebay seller in So Cal but I think they changed their seller name recently.
FFPM571
The Mid South
They are all being made in China by LindaWang... the california shipper is just a name..
mancow
N.E. Kansas
Same, it was like OEM.
prcguy
There is more than one mfr, I posted pics of my XTS2500 with aftermarket case on another site and so did somebody else. There were a couple of obvious differences in the fit and finish between the two cases. I just got lucky picking the right seller in my case.
com501
IF somebody figures out which seller(s) have the -good- cases, please post this to save everyone else the hassle of ordering multiple cases and returning the bad ones.
FFPM571
The Mid South
There are early and late versions of the same case made by LindaWang. The later ones are more refined. some unscrupulous sellers on Ebay and Facebook who sell these recased radios for mission critical uses
