Skyhealth 1 (N347MT) started in 2014 and is based in Long Island, staffed by Medtrans pilots and Northwell Medcrew. Aircraft is bought and owned by Northwell vs Medtrans. As previously discovered we are on the MTA MRRS and I couldn't tell you which TG but it is through Northwell CEMS. It's a joint venture between Northwell and Yale, so we do flights in NY, CT and RI. Transfers only on Long Island, we can do scenes in CT but too far away to actually do any, only about 7-8 scene flights since 2014 in CT. Transfers for the Northwell hospitals down in Long Island and transfers for the Yale system up in RI/CT. We also pair up with the Yale pediatric team for specialty flights.
We are busy enough now to justify a second aircraft so Yale through Medtrans has added their own aircraft (N253MT) Staffed by Medtrans pilots and Yale Medcrew. This is based at Bridgeport Airport in CT. We are dispatched and operated on the same MRRS system and TG. There is also an older VHF 155.205 PL 67.0 in East New Haven CT that is used as a backup in case we get out of range of the MRRS system going towards Eastern CT RI. It is patched and simulcasted at the console at CEMS. 99% of the time we are transmitting on the MRRS system in the aircraft.
