I have one 6ft piece of copper pipe being used as a grounding round about 2 feet from my window and about 5 1/2 feet in the ground. Is it ok to "home run" all my grounding wires to this one grounding rod with a left over cable company grounding clamp.
This is what i have connected to my grounding rod
My antenna block
My 9:1 Balun
My ground terminal on my radio
The grounding wire is as short as i can make it using insulated heavy duty braided copper wire.
Thank you
Mike
My antenna block
My 9:1 Balun
Thank you
Mike
