I mentioned in a post a while back regarding my beam getting destroyed by a severe storm. Since August I've reverted back to dipoles. I live in an HOA with a new president who isn't tolerating any bending of the rules. Between that and the matter of my wife and I considering moving within a year, I decided not to re-erect the beam.
Currently, I have a delta loop for 80/40, a fan dipole for 17, 20, and 10, and a single dipole for 15 meters. I'd like to eliminate two runs of coax and use a ladder line fed dipole. I've experimented some with home made ladder line and was not satisfied. Therefore, I am considering ordering a Dx Engineering ladder line dipole. Their package is likely cheaper than purchasing all the parts separately and building one.
I have an old MFJ 962C transmatch with a built in 4:1 balun. Current thinking is one would forego the 4:1 and use a very short run of low loss high quality coax to a 1:1 isolation/choke near the station entrance which then would connect to the tuner.
Here's my conundrum: If I do it right, I would need the DXE ladder line dipole, an array solutions ladder line static suppressor and a 1:1 choke made specifically for wide range impedance ladder line. This puts me in the ballpark of $250.00 or so. Alternatively, I could simply purchase the DXE ladder line dipole, calculate the correct length of ladder line and run it directly to the transmatch to the 4:1 balun built in – a much cheaper solution.
IMPORTANT: My station is on the second story of our home, so no practical ground exist. I have read that it is necessary to have a good ground on the transmatch when running ladder line; this concerns me.
After a ridiculously long explanation, I'd like hear from some of you who are using ladder line and how you route it, what type of balun/choke you use, and if you use any type of static drain. Am I being overly cautious and concerned?
Thanks for the patience.
