Zetron model 30 and Yaesu FT-8800
VA3XDJ
Here's a thought:
I have a Zetron model 30 worldpatch and a Yaesu FT-8800.
I was wondering if I could connect the Zetron to the Yaesu using the packet connections from the DIN connector on the back.
Has audio in both directions with respective grounds. PTT and COR.
So what modifications would I need to make before connecting the two?
I would power Zetron from same power supply as Yaesu.
Thanks!
Michel
VA3XDJ
Also how do I handle the decode issue? Do I simply ground it permanently?
VA3XDJ
Looks like the radio and controller will be able to handle eachother without any modifications.
I'll post my results when I scavenge a PS2 keyboard cable.
VA3XDJ
Will be a simplex phone patch connected to a magic jack using my FT8800 setup as a base.
KJ6HCB
San Luis Obispo, CA
Ah, very cool! Please share more info and pics etc as you set it up! I would be very interested in doing something similar. Thanks!
VA3XDJ
Looks like I'll need to order the CT-39A packet cable to simplify the hookup.
Anyone know where I can find the connector for the Zetron model 30?
