Zetron ZR310 programming
Pottstown pa
I have a zetron ZR310 controller set up with my repeater but I can’t find a pin out for the program cable anywhere for the rj45 program port on the front.
Is there a premade cable out there for this or do I need to make one.
I already have the true dos computer, gm300 software and have switched to repeater mode but can not get it to read with my current cable granted it’s not the highest quality.
petnrdx
Hudson, FL
It should read with the normal GM300 RSS using a Motorola RIB and the same cable that you use for the two GM300
radios.
Manual is on the Repeater-Builder website in the Zetron files area.
