Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 01-11-2009, 01:02 PM
bReed11091's Avatar
Default Michigan Skywarn Repeater Information
I've looked for callsigns for these repeaters in several different places, but I cannot seem to find it. I'm using a 2006-2007 repeater book, and I know at least a few of these would be in a newer one. If anybody can give me the callsign and any other information regarding their ARES, RACES, and Skywarn use, that would be great.
These are listed by the county they serve, frequency, offset, and any known tone (may or may not be correct):
Kalamazoo 444.050 + 131.8
St. Clair 147.320 + 131.8
Thanks for you help! It's for my Michigan ARES, RACES, and Skywarn frequency information project. PM me for more details on that.
KD8FJI
BCD996T, BC80XLT, TM-D710A, FT-1802M, VX-170
Old 01-11-2009, 01:11 PM
A lot of the info can be gotten from the database here on RR. Just go to Michigan and click on individual counties. The info you're looking for is usually listed first.
Hoofy
"A computer once beat me at chess, but it was no match for me at kick boxing."
Old 01-11-2009, 01:59 PM
crossfire291's Avatar
Send a message via MSN to crossfire291
i did find out that that these are both HAM freqs. thats all i can figure, with out being from your area.
cheack out this link. just click on st clair or kalamazoo to look at the freqs for that area...
thats the best i can do for you, sorry if it doesnt help
http://www.radioreference.com/apps/db/?stid=26
Old 01-11-2009, 02:06 PM
MPSCS's Avatar
Try this:
http://www.radioreference.com/apps/db/?aid=2584
Old 01-11-2009, 02:34 PM
bReed,
Don't worry about the call signs of the repeaters. These may change depending on who is sponsering or owns the repeater. The frequencies are the main concern.
Hoofy
Old 01-11-2009, 07:53 PM
SEMTTP's Avatar
Send a message via AIM to SEMTTP Send a message via MSN to SEMTTP
One thing to remember. If the repeater is not a "coordinated" repeater then they will never be listed in the Repaeater Books. Only coordinated repeaters show up there. There are many a repeaters that are in full use but do not show up in the book. The best way to get the callsign of the repeater is to monitor it. Listen for the call sign in morse code and or a voice identification. Last, put your call sign out there and ask where the repeater is located and the name of the repeater.
BTW...before posting this, I done a search on both of your frequencies that you listed and could not find anything on them.
Hope that helps
Eric-KB8UYC
Dispatcher for FNNM(fnnm.net)
http://flickr.com/photos/erchambers
http://kb8uyc.wordpress.com
Old 01-11-2009, 10:24 PM
MPSCS's Avatar
Michigan Skywarn Frequencies
http://www.lansingarpsc.com/netfreqprint.html
Old 01-11-2009, 10:37 PM
mikey60's Avatar
Originally Posted by SIG-INT View Post
I know the Oakland County frequency on that listing is incorrect. It's listed as 145.25, we've been on 146.900 for well over 2 years.
http://www.psredit.com
Old 01-11-2009, 10:44 PM
MPSCS's Avatar
Red face
It figures. I'm not a ham, just using Google, trying to help.
Old 01-11-2009, 10:48 PM
mikey60's Avatar
I sent an email to the guy for an update..
Old 01-11-2009, 11:05 PM
bReed11091's Avatar
You're suggesting things I've already tried. I wouldn't have posted it here if I could have found it elsewhere.
The callsign is important to me because when I program my radios, I use the callsign as the name/alpha tag. It helps me identify a repeater with a location, since it is common to have repeaters scattered across the state with the same frequency, sometimes even the same tone if they are far enough away. I'm working on a project that gathers repeater information as it changes, so I should know fairly soon after a change occurs.
These repeaters should also be coordinated, since they are used for ARES, RACES, and Skywarn purposes. If they're not, it wouldn't matter anyways because information for them is usually posted on the web.
I have sent an email to St. Clair's Skywarn Coordinator, and I should hear back sometime soon.
I'm also within range of most, if not all, Kalamazoo repeaters, so I'll be able to get information regarding the 440 one I mentioned from people I talk to on those.
KD8FJI
Old 01-12-2009, 12:10 AM
SEMTTP's Avatar
That is not true at all. However, most are coordinated. The repeater that we use here is on 145.150 and it is not coordinated, yet we do ARES/RACES and Skywarn on it. We do have a back up frequency of 146.920-the I94 Repeater, which is coordinated.
I will continue to try and help you find the callsigns of those two repeaters. Contacting Coordination will probably not benefit you in any way as they only deal with the requests of coordination and frequency pairs.
Eric-KB8UYC
Old 01-12-2009, 10:04 AM
mikey60's Avatar
FWIW, Oakland County:
146.900/100, W8OAK
Old 01-16-2009, 04:05 PM
Send a message via AIM to w8fsm Send a message via Yahoo to w8fsm Send a message via Skype™ to w8fsm
Genesee County is going to be 147.2600+ 100.0Hertz PL KC8KGZ
There is no offical skywarn in shiawasee county.
I have tried to send up dates for the skywarn info for micon but it never gets added or removed right from the RR pages so I figued they must know more info then little ol me.
Fred Moses - W8FSM
ADEC Repeater Operations MICON DTX
Old 01-16-2009, 05:53 PM
bReed11091's Avatar
Do they share a frequency with you or somebody else, or perhaps they operate on a simplex frequency?
KD8FJI
Old 01-16-2009, 10:45 PM
nope... they just don't have anything active.. i have a list in one of our books.. but like other things it needs updating..
Old 01-18-2009, 10:16 AM
bReed11091's Avatar
Just received a reply back from St. Clair County's skywarn coordinator. K8DD is the call of the 147.300 repeater, and it has no tone associated with it. Still haven't been able to find any information on the Kalamazoo repeater. Does that one even exist? There are several 440 repeaters that I've tried to get in Kalamazoo at 50 watts and haven't heard anything back.
KD8FJI
Old 03-05-2009, 12:25 AM
n8jsn's Avatar
Send a message via ICQ to n8jsn
I believe Kzoo uses 147.000 for skywarn.
Also, Kent Counties Freq on that list is wrong. We use 145.11
Maybe the state coordinator should put together a list on the MI ARPSC web site so all the info is in one place and hopefully correct
Tags
ares, callsign, races, repeater info, skywarn
Similar Threads
Motorola conventional repeater systems query Wyandotte Motorola Forum 3 10-26-2007 08:30 AM
New way to find LTR repeater numbers w/ 246T Gilligan Uniden Scanners 5 11-17-2005 01:33 AM
2m / 70 Cm Repeaters in Mississppi KC0STG Mississippi Radio Discussion Forum 4 11-06-2005 05:57 AM
Emergency Information on XM Nationwide Public Safety Channel 4phun Tavern Archives 9 09-11-2004 02:07 PM
Question regarding FCC classification code milf General Scanning Forum 6 05-21-2004 01:22 PM
