430-470Mhz antenna on 403-470 ht 750?
MttM1250
I'm not radio savy so this might be a dumb question. Can I use a 430-470Mhz UHF antenna on my UHF ht 750 that's 403-470MHz without harming it? Or should I just buy a 403-470MHz antenna?
K4EET
Chaplain
Severn, Maryland, USA
Hi Jackv11 and welcome to Radio Reference! There are no dumb questions around here...
To answer your question, that depends on what frequencies your Motorola HT750 is programmed for. Are you below 430 MHz by much?
MttM1250
Thank you for your response.
I checked in CPS and every channel in "Conventional Personality" is set to 470.000000MHz so is that fine if I don't go below 430 with these antennas?
K4EET
Chaplain
It sounds like your Motorola HT750 is not programmed for anything yet. The antenna needs to match your operational frequencies.
N5XPM
Texas
To narrow in a bit, the key factor is the frequencies you will transmit on. If you will transmit only between 430 and 470, you are good to go. If you transmit only from 450 to 470, you could even go narrower with a 450 to 470 antenna, with possibly better results. A 450 to 470 antenna should receive adequately from 430 to 490 or so with no damage to the radio.
MttM1250
Thank you for clearing this up!
MttM1250
I seemed to have made a mistake. Every channel has a different frequency, as seen on CPS. I have 13 units (750's and 1250's) that work with each other on channel five that are all set to 470. So as long as
I transmit between 430 and 470 with these antennas; I should be good to go according to the user. Thank you for your help.
K2NEC
Dare I ask what you are using these radios for?
hill
Middle River, MD
Going forward you need a FCC licence to use that frequency that is programmed into the radio already and looks just to be just a random one programmed in the radio.
You can't just use the 470 frequency already programmed into the radio, since you don't have licence for it. You can land in hot water and be in big legal trouble if you interfere with a licensed user
You could use it for 70 CM ham radio is you have a ham radio licence.
If these radios are Type Accepted for GMRS and you have licence from the FCC for this service you can use it on GMRS.
MttM1250
I won't be doing anything with them until I legally can, but I originally intended to hand them out to my employees at a private warehouse. We decided to go with analog and these specific models because they're a lot cheaper due to them being older, and they work well.
Tech21
Get fully licensed and it's probably best to at least consult with your local radio shop to get properly licensed. Don't just choose random frequencies and start talking on them because you may just choose one that happens to be already used and you will just cause interference and possible get an FCC sniffer on you.
K4EET
Chaplain
Jackv11, should you get the crazy idea to use those radios without FCC authorization, you might want to take a look at this first. A friend of mine works for the FCC's Enforcement Bureau (EB) and they are very good at what they do. If you have a minute, take a look at some of the $75,000 fines o_O they have recently handed out headlined on their homepage (just click on the banner below):
I doubt if you want to see your warehouse listed there. So please do the right thing...
MttM1250
Thank you for sharing this. After doing some research, I'll probably just use an FRS frequency with the authorized FRS bandwidth since I can't use GMRS at a business.
