Gotcha.. so with a Motorola 800mhz antenna will that just be able to scan 800mhz or others? Do I need a separate antenna for vhf? How do I do this
Those little low profile antennas are going to work OK on their specific band only. If 800MHz is the only band you want to listen to, then it would be an option.
They are not a high performance antenna. They are designed primarily for low profile, performance is secondary. If all you want is the looks, then go for it. But if you want something that works well, then it's not what you want.
If this is -only- for a scanner, get one antenna that covers what you need. Yes, you can install multiple antennas and multiplex them together, but that gets expensive. Get one antenna that does what you need. Mount it properly on the roof of your vehicle and enjoy. Since your SUV should provide a good ground plane for the antenna, get something like the Larsen mentioned above or the EMWave. It'll work well on VHF, UHF and 700/800MHz.
Larsen NMO150/450/758SF Tri-band Mobile Antenna covers 150-174, 430-520 & 750-870, 100 Watts, Length 16.5 in, NMO Mount, Spring Base
theantennafarm.com
EM Wave EM-M43002 Tri-Band 150-162/450-490/763-870 MHz Mobile Antenna - 17.7 in - NMO - Spring Base
theantennafarm.com
Skip the ham radio antennas. While they'll work, they are tuned for specific portions of the VHF and UHF bands only. You'll get better performance out of an antenna that is actually designed to work where you want it. Since AIRS uses 700 and 800MHz band, you want something that will cover that. The two above antennas will. Plus they'll give you some decent performance on VHF and UHF.
Remember that the antenna needs to be properly mounted. Permanent mount in the center of the roof is ideal. You want that metal plane under the antenna for it to work to it's full potential.
