Butel ARC300 Sort Frequencies
AA4BK
Central North Carolina
Is there a way in Butel ARC300 to automatically sort the frequency list? I understand sorting frequencies in memory will often speed up scanners. I don't know if that applies to the PRO-163 and PRO-164 or not but I'd like to try it. I don't see any way to do that in Butel ARC300. Is that functionality in the software, and if so, where?
pb_lonny
VK7AAL
Tasmania
Can you export to CSV, sort in that, then import it back?
I am not sure if ARC300 had this feature built in.
AA4BK
That's a good suggestion! I would prefer if the functionality was in the software but at least this might be a way to still essentially accomplish the same thing. Thank you for the idea!
pb_lonny
VK7AAL
Tasmania
I do it externally via a CSV, as I have a couple of users where I need to have them sorted differently.
Our local bus company has two repeaters which covers the city I live in and both carry the same traffic:
464.275MHz
464.375MHz
While I can hear both from home, the 464.375MHz one is closer and has a better signal, so I want that to be scanned before the 464.275MHz one.
The same applies to our state wide train network, I can hear 4 repeaters from where I live, 1, 2, 3, 4. In this case, 3 provides the best signal at home, so I have that programmed before 1 and 2.
