Decoding DMR using SDR SHARP HELP PLEASE
Coventry
So I’ve used this video (attached before) and have some great results, that was 5 years ago and I’m now getting into the hobby again.
The video gives good reference to what to download and that includes a plugin (go to 2:05) it’s off a website www.rtl-sdr.ru. Unfortaintly the software is not available anymore, can someone point me in the direction of this please ?
PDXh0b0
Woodland, WA
You will find the a lot of older plugins do not work with newer releases of sdr#
Dsdplus, dsd-fme, sdrtrunk are more current choices.
You can't go wrong with dsdplusfastlane
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
I stopped using SDR# after Version 1361 when they discontinued support for the SDRPlay line. SDR++ is a viable alternative with similar functionality
PDXh0b0
Woodland, WA
With SDR++ can you install plugins to decode DMR, POAG AND DAB RADIO ?
Sdr++ brown (a fork of sdr++) can do dmr, but not the other two yet.
You are going to find you will need/have different versions of sdr# to accommodate older plugins.
Luckily neither sdr# or plugins for it don't require an installation process (just uncompress & run)
Note that this isn't on sdr#, most of the plugin creators have moved on and no longer maintain those plugins.
The same with sdr++ , as it progresses, older, un-maintained modules/plugins no longer work.
San Diego, CA
Found it here on the way-back-machine
The link is just above the purple bar...
Jay
