Goosetown/Triangle Communications Tier 3 System
u2brent
OAMPT
KRWDPAXKRS1
I don't even know what to say anymore
Me neither, I do my best to stay out of the way of the bull. For all I know it was named as it is just to p... me off. But he could clarify that if he chose too instead of making snide remarks.
sonm10
Central MN Monitor
Sauk Centre, Minnesota
From the Date base Administrator handbook
Site Names​
Tower site names shall reflect the actual site name as used by the system, if known. If the actual name does not reflect the nearest local town or municipality, the name of the nearest hamlet, town or municipality shall be added in parenthesis after the site name; for example, "Big Tall Mtn (Little Teeny City)". Using "Actual Name (Physical Location)" will help prevent confusion when service techs and others refer on air to a site using the official name; giving the actual physical location will aid those with enquiring minds.
If the site name is a well-known feature named on a map, a hamlet/town/municipality name is not necessary.
If the actual site name is not known, the nearest town, municipality or census-designated place shall be used.
u2brent
OAMPT
KRWDPAXKRS1
What question was posed and then ignored? Just curious. This is getting to be a big thread.
Question was why site 203 is named Quarryville? period. Thats it. Just expected a simple answer, I'd have been pleased. but nope, I get this.
It's Site 203, listed as "Quarryville" in the RRDB for uh...reasons.
CqDx
US
So I was browsing the Spyserver earlier tonight and tuned into the Buffalo Airspy receiver that someone generously put up. I noticed the following two sites while scanning up and down the band. The neighbor site channel number looks funky but here are the findings:
454.6625 - 13.7
424.750 - 26.2
This seems to be the continuation of the same system that was researched back in 2022 on this thread ?
GTR8000
NY/NJ Database Guy
BEE00
Saia has settled on a MOTOTRBO Capacity Max system to replace the Connect Plus system. What you are seeing are remnants of them testing a Selex system up there. You can disregard those findings, they're no longer relevant.
DaveNF2G
Latham, NY
454.6625 - 13.7
424.750 - 26.2
Slightly OT, but do you get audio from DSDPlus when you monitor systems on the Spyserver network? I haven't been.
CqDx
US
I didn't have issue using DSDPlus through spyserver. I use virtual audio cable and make sure I don't have Monitor Source Audio enabled in DSDplus input settings to avoid looping effect.
pro92b
Mutated Member
The neighbors list on site 131 changed this morning. It was 111, 112, and 130; now it is 121 and 130. The control channel for 121 is listed as 478.825 which is/was the control channel for site 111. Nothing on the FCC site indicates where this site 121 could be. I can't receive 478.825 here so maybe someone nearer NYC could check what the neighbor list is. This whole thing might be just a typo entered into the site 131 neighbor list.
seagravebuff60
Short Bus Reject
Im still receiving site 111 on 478.825 from Northern Westchester. Nothing from my Southern Westchester location, tho.
pro92b
Mutated Member
Looks like someone at Goosetown fat-fingered the neighbors list for site 131. Is the neighbor list for 111 still 112 and 130?
GTR8000
NY/NJ Database Guy
BEE00
Yep, added it to the database a few hours ago.
seagravebuff60
Short Bus Reject
The site is showing up as isolated according to DSD+. Also, If the Control channel is 472.0625, then why was it showing as 478.825 before on site 131?
pro92b
Mutated Member
It still is showing 478.825 in the site 131 neighbors list. It's an error because I received the control channel on 472.0625.
DaveNF2G
Latham, NY
What I meant was, can you hear the decoded audio?
pro92b
Mutated Member
DSD+ 2.448 has corrected site designations for this TIII system. All relevant files need to be updated in DSD+.
