gonzalu
OK, so, am I totally confused? When I am setting up discovery mode, I thought I can only record up to 3 or 6 minutes whatever that was?
So, can you elaborate? I am sorry if I missed this in the manual, but I need help then
--Can I set up the HP1 to simply record EVERYTHING until the card fills if I chose to?
--Short of that, if I am discovering a system, can I record all activity? Not just NEW discoveries but also all the well known ones if DB check is on or all if DB check is off, etc.
Thanks all... it is good to know I can use a bigger card. So I just insert it into my scanner and let [it] or Sentinel do automagic on it? How big a card can be inserted? I have a lot of Class 10 and greater 32 and 64 GB cards since I am into photography as well.
Cheers!
Manny, N2MAV
Cheers!
Manny, N2MAV
