Minitor 5 Malfunction
schmidty678
I have a Motorola Mintor 5 issued to me by my fire department. It worked fine for months. However, just recently, after the pager was activated when we got a call, nothing was recorded in the voice storage and the pager essentially shut itself off. After this happened multiple times I replaced the battery. No change. I tried reprogramming but had no luck.
Does anyone know what might be causing this?
krokus
Southeastern Michigan
Try another charger, just in case the one you have is defective.
Sent via Tapatalk
DJ11DLN
Mudhole, IN
Sent via Tapatalk
+1 on this, we had some defective chargers with ours, caused similar problems or just very short battery duration. Also had some bad /\/\ batteries that refused to hold charge even new, had better luck with replacements from Batteries + Bulbs.
