Motorola quick call II B four digit/number tone decoding
jmbialk1
Hello, I work at a dispatch center and we are stumped trying to figure out how to decode the four digit/number code the motorola 7500 series console uses to create the audible two tone alert for minitor devices. For example one of the codes used to create a two tone alert is A29B, we dont want to/ know better than to mess around with the system but want to figure out the frequency codes to be able to be programmed into a minitor. I have found the tables in the system that show the frequencies but cant quite figure out how to translate the code and find the correct table it uses. I know that it is motorola quick call II B, any help or a table that shows a possible conversion would be helpful! Or is it specific to our dispatch center and only our radio provider would know?
jmbialk1
FYI, he provided the translation for the MCC5500. I’m fairly certain that the MCC7500 has a different translation scheme.
Yeah I noticed that but I decoded a few at work using that chart and they matched up to the "known" frequencies we had. So appears to be the correct one at least for my center.
talviar
Uniontown, PA
funny---I've been using the antique tone/code code/tone DOS program from the Centracom 2 days and the code it gives me work perfect on the MCC7500 consoles...
firefive76
Kansas
We are discussing MCC5500 vs MCC7500. I know ours were different when we changed from 5500s to 7500s.
tyoder028
Do you have a source to get this software from? I'm trying to find it haha; I've got some CM200s and a MCC 5500 console
Also, if anyone is available, since I don't yet have the software;
The codes are:
1217
1227
1237
1247
Is anyone able to list those out into the A & B tones? Thanks!
GTR8000
NY/NJ Database Guy
BEE00
Console Code​
Tone A​
Tone B​
1217600.9832.5
1227634.5832.5
1237669.9832.5
1247707.3832.5
tyoder028
Console Code​
Tone A​
Tone B​
1217600.9832.5
1227634.5832.5
1237669.9832.5
1247707.3832.5
Thanks so much for this! I had dispatch set off the tones, but unfortunately, it still did not alert the radio...I am setting up the channel to do a Call Alert so they can actually sleep at night and not hear the other stations getting toned out.
I verified RX, TX, and PL for both. The only other thing I think could be wrong is the signaling system settings?
I am going to try and set the RX PL for CSQ, and see if that will help. I'm just not sure what the AND & OR settings differentiate between...
a417
Do I want these settings OR these settings, or do I want these settings AND these settings for unmuting/signaling/squelch.
Put it in a sentence like that, and it's much easier to parse.
