Need Help With Northeast Minneapolis Frequencies
For whatever it is worth, if you are unsatisfied with the Uniden Bearcat BCD396T, you might want to consider selling it and moving up to the Home Patrol HP-1. The reason I say that is because it has essentially the entire US and Canada database pre-programmed in to it already. That would allow you to select ARMER, enter your ZIP code, set the range, select the services you want, and be scanning in a matter of minutes. The thing I like about it is that it is dead simple, BUT it also allows for advance feature if that sort of things interests you.
I had both a BCD396XT and a BCD996XT. They are both great scanners, but I found myself not using the 396XT as much as I did a couple of years ago. I sold it, got a good price for it, and bought the HP-1 with some hesitation. It turned out to be a great choice. It works great in the vehicle and I like using the GPS option. While I still enjoy using the BCD996XT at home, I could get by with an HP-1 at home if I had to.
Also, I am not sure if Uniden is still doing firmware updates on the 396T. I think they are on the BCD396XT. Thus, for Minnesota ARMER scanning, the BCD396XT may have an edge over the BCD396T. The nature of the simulcast system can be a challenge for scanners.
