New Unication G1 Tone Voice Pager
rustyjw
I am programming the Unication g! pagers for my department. Does anyone know how to program the weather channel into the pager and have it alert regardless of what channel you are listening to? I understand that it can be programmed this way, but am unsure how to do it. I also have no idea what the weather alert tone is.
vittles04
Premium Member
Michigan
Yes, 1050 10 second long time. However can you tell me is this going to be in closed "selective call" or open "Monitor Mode"?
vittles04
Premium Member
Michigan
Yes, 1050 10 second long tone. However can you tell me is this going to be in closed "selective call" or open "Monitor Mode"?
vittles04
Premium Member
Michigan
sfd119
I wouldn't put in the Weather on a public safety pager. It will not scan your tones any longer because it'll always be "stuck" on the weather freq.
vittles04
Premium Member
Michigan
Agreed...no weather in dual scan modes for concern of missing pages. However if you really really want to do you can. I have a department that does this. I always caution them but they use one of silent scan modes etc. I told them I refuse to program it in for the fear of pages were being missed I didn't want to be held liable.
hiddenrun
Commonwealth of Pa
You can put it in selective call or monitor mode. it should alert on both. If you set the alert length to 3 sec and put your primary emergency frequency on priority, you shouldn't miss your calls.
krokus
Southeastern Michigan
I would suggest not doing this. The pagers will trigger for any weather alert in the service area. How about having your dispatch trigger your tones for any significant alert in your area?
Sent via Tapatalk
wildbillx
Cape May, NJ
I have had my G1 set to selective for 4 different department tones and the WX alert and have never missed a page. Not saying it would never happen. Just remember to set a delay revert so it resets.
krokus
How do I change the volume on the alert tone on the programming software or can I do it on the pager itself for the unication G1 pager
There is a menu option for having the alert at a fixed level, or volume control dependent.
An issue I ran into was the disparity between the alert audio level and the radio traffic audio level. I installed Audacity, and edited the .wav file, lowering the level by 9 dB. Obviously, the file's starting audio level factors in.
Sent via Tapatalk
truckie27
Metropolis, IL
How do you program the weather into a scan list and only have it alert when the weather service sets off their alerts?
Sent from my Nexus 6P using Tapatalk
ffexpCP
wizard of odd
Michigan
You only want the 1050 tone. Remember it's a broadcast station not 2-way. No other tone is used.
Unfortunately the pager does not decode the modern EAS digital data, so it will trip for any alert sent on that frequency.
