How heavy is that antenna setup Nick?
Hmm well the EMT conduit is about 5 lbs. The rotator is about 5 lbs. The loop weighs about 1-2 lbs. So probably around 15 lbs.
Cool setup OZ
sometimes I think it's the cause of all the ringing in my ears but yeah it's a neat thing to get satisfying reception off something you did yourself and refined over timeThanks, making antennas and getting good results is such a buzz isn't it?
I really need some sort of shelving upgrade (running out of space) LOL
cool someone's got me rethinking of turning mine into a horizontal delta loop. I tried it once but I may have done the connections wrong so may give it a better shot.Hi Ridge HF is very busy down under,I also have a PK Loops 30 metre dipole which i havent put up yet been busy with work..
Regards Lino..
ow ow ow ow ow owww ow!Nothing fancy here just a couple Wellbrook ALA1530 loops and PAR EF SWL for HF listening.
Scanner listening done on a Creative Log and a Comet GP9NC commercial antenna (not pictured)
I also have some satcom antennas but only a photo of one. When I clean up the other side of the yard maybe I'll post the others
Nice! Are you gonna raise it higher-looks like you have enough feedline to get it above the houses. How do you like its reception across all the bands?My new Pixel
I'm not allowed to have anything above the roof. So, it will have to work at this level. So far, it's working pretty well, but I have only just begun listening. I am comparing it to my DX Eng. active whip.
Right on Nick-I appreciate that-like on my system I'm "grounded" to that fire escape which is bolted to the building's steel frame, and it very much quieted RFI. Like ka3jjz once suggested to me, it could be just a huge counterpoise much less a real ground from up here. I just want folks who have had RF quieting via ground or counterpoise to list it here for rf grounding tips for folks doing HF installs..Ridge not every antenna requires a ground. In fact, I think you may be getting the term mixed up with counterpoise. Generally, grounding refers to electrical safety because it's connected to Earth. Counterpoise refers to a "virtual ground" which isn't connected to Earth -- instead we use extra wire or radials to create this low-resistance ground. The lower the frequency the more the ground counterpoise is necessary. This is why you don't see them when using VHF or higher.
I'm sure Token can jump in here to elaborate.
I understand the g5rv is a dipole, not requiring an RF ground but was wondering if he had a grounding to it anyway.
