Pro-163 Ottawa EMS EDACS
mikewazowski
Forums Manager
Oot and Aboot
Can't comment on the programming as I'm unfamiliar with that scanner but rebanding doesn't apply to Canada.
DaveH
Ottawa, Ont.
Rebanding does not apply to EDACS, only 850MHz Motorola systems.
The PRO-163 can be programmed for the EDACS system. Be aware,
these are special-purpose EMS channels used for events etc. including
Winterlude. Main EMS activity is on Ontario-wide Motorola VHF system
which you can also receive:
Bell FleetNet - Ontario Provincial Government Zone 2 Trunking System, Southeast Zone, Ontario - Scanner Frequencies
In case you're not aware: forget Ottawa Police on EDCAS on your scanner (or any other); but there are other ways to receive
them.
Dave
colinzim
Ottawa, ON, Canada
Thanks for your replies !
I was listening to the below feed thru the net and if I can receive Ottawa EMS and a few things that would be great !
Ottawa Public Safety
Feed Notes
This scanner feed is set to follow:
  • Ottawa OPP (2OPS37, 2OPS34, ONLY)
  • Ottawa EMS (Alpha, Bravo, Charlie, Delta)
  • Ottawa Fire including Airport Fire
  • The scanner does not broadcast O.P.P TAC talkgroups or TAC EMS talkgroups
The scanner has been re-programmed to stream line the scanner activity for the Ottawa Area.
The current reception location is Ottawa West.
