TPKeller2
I have noticed an irritating human factors condition with regard to the Mode button on my PSR-300.
When I am scanning at night, I will often press the Light button in the lower left corner of the key pad so I can see what channel the scan has stopped on. Sometimes as I do this in the dark, I will accidentally press the Mode button, which is directly above the Light button.
This is bad. It changes the mode of the channel to an improper mode, which can result in degraded sound quality. If I pressed the Mode button instead of the Light button, I also don't know which channel it was that I just changed, so then to fix it, I have to step through all the channels that I'm scanning to find the one that was just set wrong.
Now there very well may be a good reason for it, and I suppose that is what I'm asking, but why doesn't the Mode button only apply when a channel is in "Program" mode? I would seem reasonable to me that once I set a mode for a channel (at the time of programming) I would not want to be able to easily, and certainly not accidentally change that mode to something else.
What am I missing?
Theron
What am I missing?
Theron
