I am planning to buy a new scanner to monitor Cabarrus County. What models are you folks in the area using? Are you happy with them? Is the data that can be downloaded from Radioreference.com current and sufficient for programming. I would like to use software to program the scanner. I used to listen several years ago on an older scanner but it can no longer be used to monitor since Cabarrus County changed systems. I would like to be able to listen in again. Thank you in advance for your help.
