Scanning capacity plus with Motorola DP4600e radio
Hey all, I am having some trouble trying to figure out how I could scan a capacity plus system using a motorola radio. I had a TYT-MD380 that I was using to scan all 4 channels of the system, both frequencies on each time slot. I am authorized by the company that owns the system to listen in what's going on. I have configured the capacity plus system in the radio and it can tell if it is in/out of range. Only problem is that most of the calls are private calls. With the MD-380 I had an option for private call decoding, meaning I could hear private calls that were not pointed to my radio ID. Is there a way to acheive a similar result using a Motorola radio ?
K2NEC
Motorola will not be able to decode private calls unless you are the intended recipient
Thank you for the recommendation, but for almost 200$ I will pass 😬. That's more than what it'd cost to buy a TYT-MD380 and listen in with this instead. It doesn't even seem to support CAP+ that well.
Mogley
Just buy a dmr scanner. Or use your md380 in promiscuous more via md380 tools
