TK-890 Motor Install Complete
Kenwood TK-890 Install on 2009 BMW R1200RT-P
It’s taken awhile to dedicate sufficient time to this project, but the TK-890 is now mounted in the radio box and is fully operational. I want to thank “ramal121” for his sage advice along the way. Once I decided to go with the PVP Communications solution for a wired interface with the PA function, I was well on my way. The only critical element remaining was acquiring the PVP ADAPTER CABLE, SPECTRA TO KENWOOD ($45.00) from PVP. Using this adapter cable eliminates having to invent the interfaces, and makes for a very clean and straight-forward install.
The install requires the TK-890 UHF Radio with Mounting Bracket, KCH-11 Control Head w/Bracket, KRK-5 Remote Kit, KCT-22M2 17’ Control Cable, KCT-18 Ignition Sense Cable, PVP Adapter, PVP Headset, and PVP Electronics Box. You’ll also need the Radio PTT Switch and PA PTT Switch. As with every install, you’ll want to have the entire system operating properly on the bench, ensuring all functionality is verified, before engaging in the installation.
The Remote Head Mounting Bracket requires two slots to be elongated in order to use the BMW handlebar post extensions. This install also required a 3-hole button mount for the Siren Control (which is disconnected), Radio PTT, and PA PTT. Things get pretty tight under the left grip and clutch handle with the bigger bracket, but driving a few miles while using the new features eventually makes things more comfortable and automatic.
A discovery on bench was that the Radio PTT didn’t work. It turns out that the PVP Adapter cable is wired for Function Port AI5 for the external PTT function, but my version of the TK-890 and programming SW only allowed for Function Port AI1 to be programmed for the external PTT. That discovery required a quick re-wire of the adapter to accommodate AI1. Again, it is much easier to resolve issues on bench than after installation.
No attempt was made to try to squeeze in a Kenwood external speaker. The BMW pre-wired left speaker was used, and even with the radio being programmed for the normal audio output level (not 13 watts), the audio from the speaker is substantial and very clear. The Radio PF5 was programmed for Speaker Int/Ext, and since there is no internal radio speaker with the KCH-11 Control Head, PF5 allows the BMW speaker to be muted, while leaving audio in the helmet headset. PA PTT works great, once the audio level adjustments are made using the PVP level set pot. The PVP headset works great even at high speeds, providing more than enough audio, and the noise cancelling works great on transmit, as reported by numerous radio checks.
The broad-banded Maxrad PC Tel UHF antenna keeps with a low profile, while easily providing good performance and SWR from the 70 cm ham band up through 469+ MHz.
I’ve included a few pictures just to show what it looks like after completion. Not very exciting, but pics nonetheless. The PVP solution is the absolute best way to go. Their products are designed and manufactured for the demanding motorcycle environment, and the performance is outstanding. This is not an inexpensive solution, but it is by all standards, the best solution.
