AricAAA
- Joined
- Sep 14, 2010
- Messages
- 12
I have been scanning the airwaves in Windsor and Essex County for over 2 years now using a Pro 96. I had programmed all the agencies around me manually and they worked fine, including Bell Fleet Net in the Windsor-Essex area.
With regards to Fleet Net Zone 1, while in Windsor, I got OPP, EMS, and MTO loud and clear with no problems.
I've recently moved to downtown Oakville, Ontario, in Halton Region. I pickup Halton Regional Police no problem.
However, when I try to program the fleetnet system for the Halton Region and the GTA, I've gotten pretty much nothing from the OPP or EMS.
I've even tried programming my scanner using Win96 and the radio reference database. I've programmed all the towers in and around Halton.
After programming by computer failed, I tried programming fleetnet manually, with all talkgroups. But still I've gotten barely anything. As far as I know, I've set the base frequency, offset, etc. all correctly. Is there anything that I might be doing wrong?
Thanks in advance,
-Aric
Thanks in advance,
-Aric
