Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > All Other Scanner Manufacturers
All Other Scanner Manufacturers - The forum to discuss all other scanner manufacturers not listed above.
  #201 (permalink)
Old 06-27-2016, 2:14 AM
It't just a promises. Heard the same in April & May. And I can suppose, that we will hear it in July, Aug.
  #202 (permalink)
Old 06-27-2016, 7:34 PM
mrscanner2008's Avatar
I'm sure he's just busy... we have to remember this isn't his day job.
WWW.VE2DRO.COM
Icom IC-91AD, Yaesu FT-8900R, Icom IC-7000, KX-3, FTM-400DR (Fusion),Icom IC-R20, BCD396XT,(2)BCD996XT, PSR600, HomePatrol 1, (2)BCT15X, (2)BCD436HP, BCD536HP and TRX-1
  #203 (permalink)
Old 06-28-2016, 12:14 PM
moj moj is offline
Default Adcr25
Give Andrey a break , the guy has brought a receiver out that works and has slight bugs that need ironing out but he's been true to his word and as others have said he has been really busy yet he still answers back to emails and has added features other boards haven't so I'm happy to wait a bit longer for any updates also any idea why the forum that he also reply's on isn't working at all at the minute ?
Also Andrey could you make a more detailed manual explaining the nxdn/idas code decryption side of things better and a step by step what the button keypresses are on the menus to decode these etc
thanks
  #204 (permalink)
Old 06-28-2016, 4:00 PM
they delivered what he promise, instead of Uniden that after more than 2 years, the x386HP doesn't have all the promise features.
just my 2 cents
WWW.VE2DRO.COM
  #205 (permalink)
Old 06-28-2016, 9:37 PM
Are there plans to add Enhanced Privacy support at some point...?
"Huhh?? Of COURSE I don't have enough radios, shouldn't that be obvious??! My vehicle has lots of space to put more radios, I certainly do NOT have enough!"
  #206 (permalink)
Old 07-08-2016, 2:52 PM
moj moj is offline
I think I'm going to answer this for everyone seeing as nobody has replied back to you, its not even looking like a possibility with the adcr25 and you would need a very powerful processor and probably a super computer to bruteforce an enhanced encryption code so sadly I doubt this would ever be a feature available on this board.
Would be ideal tho if this feature was implemented but don't hold your breath !!
  #207 (permalink)
Old 12-29-2016, 10:12 AM
Hello,
I downloaded software v.5.10 but what is the hardware that I can use it with? From PDF I see that this is similar to tuner RTL-SDR. Where can I buy it?
  #208 (permalink)
Old 12-29-2016, 10:14 AM
Forts's Avatar
Mentor
You need the ADCR hardware which is no longer being sold.
  #209 (permalink)
Old 12-29-2016, 5:54 PM
buddrousa's Avatar
Forts I would guess he received a letter
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
  #210 (permalink)
Old 12-29-2016, 7:20 PM
Forts's Avatar
Mentor
I wondered that as well... but considering he's in Russia...who knows!
  #211 (permalink)
Old 12-29-2016, 7:37 PM
buddrousa's Avatar
Motorola sells in Russia also that might be a way to pressure him.
  #212 (permalink)
Old 12-30-2016, 5:15 PM
He also removed the 1-4 splitter from the site. I guess its just time consuming trying to run the projects alongside his daytime job. The 1-4 splitter worked excellent but the ADCR25 not so much.
I manage to get FW 5.11 from him to get amateur Fusion working but I guess thats the end of it.
/Ubbe
  #213 (permalink)
Old 12-30-2016, 5:28 PM
/Ubbe
can you post FW 5.11 i would like to try it !
WWW.VE2DRO.COM
  #214 (permalink)
Old 12-30-2016, 5:30 PM
mancow's Avatar
Ya me too please.
  #215 (permalink)
Old 12-30-2016, 6:24 PM
moj moj is offline
I'd also appreciate a link to 5'11 if you have it Ubbe , thanks in advance
  #216 (permalink)
Old 12-30-2016, 7:07 PM
buddrousa's Avatar
Yes I would also like the 5.11FW
  #217 (permalink)
Old 01-05-2017, 6:32 AM
mclove's Avatar
  #218 (permalink)
Old 01-06-2017, 12:46 PM
Default ADCR25 FW5.11 400MHz
This is the 400MHz only version that I have of FW 5.11 for the ADCR25 board.
Only change (bit order) from 5.10 are the needed narrowband fusion demodulation neccessary to decode amateur radio.
It is a quick fix from Andrey so the info will still come up as FW 5.10
/Ubbe
  #219 (permalink)
Old 01-06-2017, 12:48 PM
mancow's Avatar
I can decode fusion with 5.10
  #220 (permalink)
Old 01-06-2017, 1:06 PM
I don't know the reason, but the local fusion amateur repeater where I live didn't decode so he said he needed to change the symbol order in the decoder and that fixed it. He sent me the FW file and it was labeled 5.11
/Ubbe
