Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify / Live Audio Listener Support
Broadcastify / Live Audio Listener Support - This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 05-10-2017, 9:00 AM
Default Live Audio Tags
I often listen to feeds on a PC and Apps on iPhone/iPad. On some of the different Apps I am able to see tags on some of the feeds, however when listening on a PC I am not able to see the tags. Any advice on how I can see Tags when using the Broadcastify on a PC
Old 05-10-2017, 9:05 AM
W8RMH's Avatar
ScannerLive
Old 05-10-2017, 9:08 AM
So Broadcastify does not provide tags?
Old 05-10-2017, 10:14 AM
W8RMH's Avatar
Broadcastify provides alpha tags if they are included in the feed provider's stream. Your media player will determine if you see the tags. Some media players will display them and some won't.
Old 05-10-2017, 10:23 AM
Thanks for the update to this. I was using the default HTML 5 Web Player and never realized it. I will try a different player. As for as Scanner Live apparently I have to pay to use it. Can you advise what are the advantages of using Scanner Live versus using the Broadcastify site
Old 05-10-2017, 4:59 PM
Spitfire8520's Avatar
The features that it offers are pretty well stated on its website. It basically turns your computer into a scanner of many live feeds.
If you only want to monitor a single feed, there are a few media player applications that can be downloaded that will display the alpha tags. I use VLC for when I want that kind of support, and there are quite a few other options out there that are just as good. It all depends on personal preference.
Mile-High Spitfire
RadioShack Pro-106 RadioShack Pro-652 RTL-SDR
MNN-250
Old 05-11-2017, 1:38 PM
To show the Alpha tags, the Scanner / Host Feed must be broadcasting them and you must select the right way to view the alpha tags. I know iTunes shows the alpha tags. It is a free download from the web and then just go to the feed in iTunes and it will show them.
Encryption Kills Interoperability
Radio Shack Pro-94 / Pro-197 / Pro-651, Uniden BCD996XT, ICOM A-214, Baofeng UV-5R V2+ (3) / UV-82, Kenwood TK-880, Motorola HT-750 / CT250, TYT TH-7800
Old 05-24-2017, 11:55 AM
rcool101's Avatar
Originally Posted by W8RMH View Post
ScannerLive does not show tags
BCD396T GRE PSR 600 BC246T BC780XLT BCD396XT HP-1E BCD536HP BCD436HP
