Live Audio Tags
teebee
Lake Charles, LA
I often listen to feeds on a PC and Apps on iPhone/iPad. On some of the different Apps I am able to see tags on some of the feeds, however when listening on a PC I am not able to see the tags. Any advice on how I can see Tags when using the Broadcastify on a PC
teebee
Lake Charles, LA
Thanks for the update to this. I was using the default HTML 5 Web Player and never realized it. I will try a different player. As for as Scanner Live apparently I have to pay to use it. Can you advise what are the advantages of using Scanner Live versus using the Broadcastify site
Spitfire8520
Might be slightly less clueless! =)
Colorado
The features that it offers are pretty well stated on its website. It basically turns your computer into a scanner of many live feeds.
If you only want to monitor a single feed, there are a few media player applications that can be downloaded that will display the alpha tags. I use VLC for when I want that kind of support, and there are quite a few other options out there that are just as good. It all depends on personal preference.
drayd48
To show the Alpha tags, the Scanner / Host Feed must be broadcasting them and you must select the right way to view the alpha tags. I know iTunes shows the alpha tags. It is a free download from the web and then just go to the feed in iTunes and it will show them.
