GBLOCK
Running into issue when trying to update firmware in a XPR6300. Tried CPS 13.5 and 15.5 NA. I can read and write radio so i know its not the cable. Its just when I try to update the firmware via UPDATE or RECOVER I get "Error #2898 Unable to establish a connection with the device. Please reset the device, reconnect it and try again."
When I start the update process, the led on radio goes solid green. The radio goes into the boot loader mode and the error #2898 appears.
Motorola XPR6300
Current firmware R01.03.02
Trying to update to firmware R01.12.17
Using MotoTRBO 13.5 Build 679 NA also tried 15.5 NA same error code
Is there a particular CPS version to use when updating gen 1 motoTRBO radios to R01.12.17 firmware?
Motorola XPR6300
