Dreamflight767
Hello:
Need some help understanding/clarifying the info. in the database please.
-So I live off of I5 between downtown and the I5 bridge to Vancouver. Which OSP frequencies should I be monitoring for this area?
-I also spend a lot of time in Hillsboro. Which OSP frequencies should I be monitoring for this area?
-The database lists Portland Area Command, McMinnville Area Command, and Salem Area Command for conventional while database lists McMinnville, Banks, and Salem under Project 25 Phase II. Why the difference in areas? For P25, what is used for the Portland Area?
Thank you!
Thank you!
