There is no remote base station for E34, I wish there was but not the case here. In the trailer they have an Icom A200 base station hooked up to a RAMI AV-1 antenna that is mounted on pipe on the front corner of the trailer under the FDR. It's fed with RG400 coax and its probably only 25' of coax. The radio they have now (Icom A200) has no issues and handles things fine. They however wanted a backup base station radio in case the current one dies. They went out and bought the Icom A220, I've tried that radio before in other locations and found it had issues not being able to squelch out. Sure enough they plug it in and complete static, squelch max, noise limiting etc, doesn't matter just straight static. I however have had luck with the Icom A110 which has been replaced with the Icom A120 which both have worked great in high noise locations. They are returning the A220 and bought the A120. Plug it in, same deal, constant static.
I'm just helping them out on the side, next time I stopped by I was going to walk around and start looking for computers, power warts, battery chargers, lights, cable wires, routers, modems etc and start turning them off and see if it was something local in the trailer causing the interference.
This antenna is in a very poor location. There are powerlines running below the FDR drive and are close to the antenna. You have a fuel farm right next to it and lots of other infrastructure around it that's just begging to cause interference. I was thinking of moving the antenna if it got to that point. To find the best spot I was going to get the longest scrap of LMR400 I had and put an antenna on a pipe, plug it in and run the cable out the door and walk around the fence line and see if I could find a quieter spot for it. Wouldn't want to go through all the work to permanently move it just to find out there are the same problems.
Was also thinking of using a filter, might try an FM radio filter to start, the Empire state building is less than 1 mile away with many radio stations on it as well as the Chrysler building.
Could also go the more expensive route and have a custom band pass filter done that only allows in 118-136mhz.
