0 squelch?
tvengr
Well Known Member
Baltimore County, MD
Open squelch is fully counterclockwise. Tight squelch is fully clockwise. you can verify that by pressing the WX button without an antenna on the scanner.
SA_tx_88116
Rather listen than to stream
Cibolo, Texas
Will it be possible to still receive stuff from all this static?
tvengr
Well Known Member
Hold on a frequency without a PL tone. Turn squelch fully counterclockwise. You should hear noise. While there is no transmission, slowly turn up the squelch until the noise just disappears. That will give you the best sensitivity. If you turn up the squelch too far, you will not be able to receive weak signals.
