0 squelch?
SA_tx_88116
Rather listen than stream
Cibolo, Texas
On a pro 197 which way would I need to turn the squelch knob to have an open squelch or 0 squelch?
tvengr
Well Known Member
Baltimore County, MD
Open squelch is fully counterclockwise. Tight squelch is fully clockwise. you can verify that by pressing the WX button without an antenna on the scanner.
SA_tx_88116
Cibolo, Texas
Will it be possible to still receive stuff from all this static?
tvengr
Well Known Member
Hold on a frequency without a PL tone. Turn squelch fully counterclockwise. You should hear noise. While there is no transmission, slowly turn up the squelch until the noise just disappears. That will give you the best sensitivity. If you turn up the squelch too far, you will not be able to receive weak signals.
