RadRom
Hi,
I have a 02 CH local/dash mount to an 8500, firmware R36 & CPS 36. The speaker on the 02 is extremely faint, almost inaudible.
I connect the 02 to my 6500 and 2500 radios in same local/dash mount configuration with both radios on firmware R32 & CPS 32, speaker works fine - (a different style/version of flex cable to 8500).
Connect 02 back to 8500, barely any sound from front speaker again.
Swap 02 over with my remote 03 8500 with firmware R27 & CPS 32, (making remote a local mount) still no 02 speaker sound, but using same flex cable.
With both 8500 radios, there is external speaker sound and both work on an E5 or 03, so it's not an audio chip issue.
I've checked all CPS settings and even import copy from a known woking 02 2500 local mount codeplug - Still no 02 speaker sound, yet sound works when connected to any other APX radio but an 8500 no matter the firmware version.
I can't compare the 8500-02 flex cable, I don't have another one to test with.
Otherwise, the 02 works fine -- Just no front speaker.
I've not come across this issue before.
Would it be my flex cable is faulty or something else to look for?
Thankyou in advance
Thankyou in advance
