ILMRadioMan
Ditto what DOC said.
The high beams are tied together.
Your wig wag module should have a wire that goes to both lights. Make sure you cut the high beam wire to BOTH lights. One of the wires will just be capped / taped, and the other one will be used to for the wigwag module.
There should be a "high beam override" wire into the module. You should splice that wire and one of the high beam wires together. Then there should be one wire for each lamp.
If you have done so, then you should be good to go and it sounds like a module problem.
