1/4 wave or 5/8?
Ubbe
Stockholm, Sweden
I'm thinking that the added gain of a 5/8 would make the frequency bandwidth somewhat the same as a 1/4 where their gain are the same.
I might, but for transmitting applications, the reflected power starts to go up pretty quick when you get away from the tuned frequency of the 5/8th's wave.
If you look at the highest frequency 174MHz for the 1/4 it is a 2.2:1 SWR and for the 5/8 it's 3.5:1
It's a 13% loss versus 30% which is a 17% difference and a 20% difference are 0.8dB
I still believe that the gain of the 5/8 will be more than 0.8dB at center frequency compared to the 1/4 wave antenna which will compensate for the 0.8dB difference in loss of signal way out of the usuable frequency range, if the direction loob of the 5/8 isn't pointing more straight up in the sky than the 1/4 will do.
/Ubbe
