Your question doesn't make any sense. If you want a useful answer, you need to indicate where you are (at least to the city/county level), what you want to hear, and what you mean by "cracking the memory".
That's obvious. You need to specify where in the UK you're located, as what you can receive in Liverpool is totally different than what can be heard in London. And "cracking the memory" is not any sort of standard radio or scanning term, so until you offer some explanation of its meaning, nobody else is going to have any clue what you're talking about. Cheers.
Exactly what does crack the memory mean? How much can it hold?
Or do you mean you want to customize what you have in the scanner as favorites lists to change quick keys That's easy you can do it in uniden sentinel and create your own favorites lists/quick keys to your liking
I wonder if 'crack the memory' means coming to an understanding of how x36 DMA actually works. IIRC, being in the UK means he can't start with the shortcut of database scanning or even creating favorites lists by appending from the database in Sentinel.
