2-Tone Decode
Jl942264
I'm looking to decode a departments Quik-Call II tones so I can program them into a pager (not for critical use) I know about the app on iphone however it keeps giving me the wrong tone set... I know the unidens can scan for the tones, however the department uses more than 2 tones in a stack, I need to decode the other tones in the stack. The Uniden only gets the first two... any ideas are appreciated!
w2lie
New York DB Admin
Long Island, NY
Two Tone Detect will round the values to the nearest Motorola value.
You can use Audacity to analyze the tones if you have recordings of them.
In audacity, you can select the audio of just the first tone, then click analyze and look at the meter to find the peak tone value.
Repeat for the second tone of the AB tone.
Then work your way through the rest of the stack.
Here is a quick tutorial for something else, but works great for paging:
Jl942264
Excellent! I'll pull a recording of it in a bit!
Thank You!
