2-Tone Protocol Question
bamx2
Indiana
I have one department with a 5 second long tone, and all the others use QCII. I am using the following two tone settings, but they will only decode the long tone, and not the short tones. Looking for any assistance.
k3sls
FM03qu North Myrtle Beach SC
Have you tried setting the "Tone Table:" to Motorola to ensure your decoding the correct QCII group? If that change works, you may need to set up two different tone protocols...one for QCII, another for the long tone.
bamx2
Indiana
I have went to the Motorola table. It works for decoding the two tone but not the long tone. It is not a standard long tone, but it is a 5 second single frequency tone. I am able to massage the timings to get the long tone to recognize, but then it no longer does the short tones.
I don't want to do two protocols, because then I cannot get the alert for both departments on the same knob.
k3sls
Yes, you can get the alerts on a single knob...here's how: Create the two protocol alias', one for Motorola QCII, one for the custom long tone. Set up the two frequencies with the proper tones in the group ID area. Now create a zone position for each freq. using selective calling. Finally, create a knob position using silent scan with pointers to the other zone positions. The last position is the one you'll keep active.
I use this method to monitor paging in two departments on different freqs. It works!
bamx2
Indiana
I did try that. However I would miss call, because it would lock in on the channel that did not have that prprotocol set.
k3sls
The only other remedy I can think of that may help is set up as I suggested, then experiment with the reset mode/delay timers in the knob function area. You might find a "sweet spot".
Scanning two (or more) freqs. will always be a bit of a gamble in regards to missing a call. Even with the suggested setup, I miss calls because the two depts. have a mutual aid arrangement and can dispatch at the same time. A Gx with two VFOs would help!
vocoder
Indiana
It seems as though long tone or custom tone adjustments changes things for the short tones. I have mine set with silent scan for custom long tone on one knob zn1 and motorola default short tone on another knob zn2. Scans 2 different knob clicks, each with the same freq but a different protocol. Like k3sls, but the same freq for both. It works ok
You might have to tweak the short tone settings to motorola qc spec
I had to tweak short tone settings to match a moto set here for a mutual aid dept
73, john
vocoder
Indiana
Have you changed any other long tone settings other than the 5k duration?
Did you try to copy the short tone settings from the moto table, into the custom table?
bamx2
Indiana
My current settings are the mototable with the longtone set to 5k.
I am hoping there is a sweet spot in there somewhere, I keep looking for.
David_Oney
Former Unication Tech Support
Raceland, KY
You definitely do not want your Long Tone RX Timeout to be shorter than 3200 ms. use the below formula for Analog 2 tone settings
optimal range for the Rx Timeout:
(Tone 1 Duration – Signaling Activity Timeout) + Gap 1 duration + Tone 2 Duration – Signal Detect Wait Time ≧ Rx Timeout ≧ Tone 1 Duration + Gap 1 duration
so for your current setting you would want to set the long tone RX Timeout to about 4400 ms
bamx2
Indiana
(Tone 1 Duration – Signaling Activity Timeout) + Gap 1 duration + Tone 2 Duration – Signal Detect Wait Time Rx Timeout Tone 1 Duration + Gap 1 duration
This is awesome, thanks!
a1emt
Did these settings help solve your issue? I have been dealing with a very similar issue relating to a long tone decoding problem possibly related to timing.
THX
