2005 Toyota 4Runner - Another install tale
W8TUZ
Logan, Ohio
After viewing WMU989's fine post on what he did with his T4R, I thought I would share my attempt at shoe-horning a radio and a scanner into this truck. I always try to install in such a way that I can remove the equipment and antennae and not leave a noticeable mark.
For the external antenna, I used a pair of Comet RS720 NMO mounts. A Maldol X-107 dual band for the Yaesu 8800 and a Larsen NMO 150450800 for the BCT15 scanner. I ran the coax from the back hatch into a rubber boot, carefully slitting the boot to admit the coax. Once inside the headliner, I ran the coax along the the top seam between the fabric headliner and the plastic side molding. I ran it down the door pillar and then underneath the seats, careful not to place the coax near the seat mechanisms.
The radios were installed in the center console, cutting just a small hole in the back corner to admit the coax, power and speaker wires. Power from the battery ran through the bulkhead and then down the center console. I used a makeshift mounting cushion in the console made from plywood and rubber grommets.
The control heads are mounted in the cab on a flexible stalk my friend found at a garage sale for $.50. I used a commercial mount for the Sirius radio and then tagged on a homebuilt mount holding the Uniden head and the FT8800 head. Power and control cables were hidden in the stalk wiring loom.
Speakers were attached using RS speakers mounted on the handhold mounts hidden behind a plastic cover. I guess my version of the T4R didn't come with a handhold on the driver's side. I choose the RS speakers solely because of their size. Besides having speakers close to the old ears helps me hear what people are saying.
I've also included a shot of my shack, small, but I like it. A IC7000 connected through a Rigblaster pro PSK through a AT2000 tuner. A 756 Pro for SSB phone connected through a AT1KP Palstar tuner and an Ameritron 811H Amp. Some Heil mic's complete the station.
Most of the ideas I used I got from reading this forum, so thanks and 73.
W8TUZ
Logan, Ohio
More Pics
Here's part 2 of the pics
W8TUZ
Logan, Ohio
Part 3
And the last part I hope you enjoyed them.
crazyboy
NJ
You know, I'm not usually a fan of those pedestal mounts but you made it look damn good!
W8TUZ
Logan, Ohio
Thanks, it was the only way I could figure out how get the radio heads where I could see and manipulate them.
Plus the price was right
jonny290
Denver, CO
Cut that abomination of an adapter train off your BCT-15 feed and get a single BNC on there. I bet you'll gain 3dB just losing those adapters and that stock '259 (if it is still stock).
Great pics!
Very nice install.
W8TUZ
Logan, Ohio
Great pics!
Very nice install.
Thanks, I had to abominate in order to fit in the console (hi)... Now that I have more time, I'll solder a proper BNC on there and see what it does. I appreciate your advice.
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
Congrats on a fine install. :) T4Rs are not too rig friendly but you and others who take the time and improvise show what can be done with a little ingenuity.
Enjoy the rig, and the rigs. :D
73
Dave AKA The tripzter
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
Very clean, very nice install. As the previous owner of a '99 T4R, I can sympathize with the lack of room for radios, but it's clear you've used your imagination to overcome that. Well done!
W8TUZ
Logan, Ohio
h8tdigitalradio said:
Hello,
73
It wasn't all me, W8TUK, Gary and I scratched our heads for a long afternoon before we came up with this idea... plus he's the one who found the $.50 flexible pedestal.
W8TUZ
Logan, Ohio
Thanks, I appreciate that.
CLTX11
North Tx
Looks very good, used up all the space you dont use, plus a little you might have wanted to use :)
How does the RS speakers work for you?
fez_uk
nice install, Those back mounts are a good alternative to drilling holes in the car roof.
W8TUZ
Logan, Ohio
RS Speakers
They are not Motorola's by any means... but they work in this application. I don't miss the space too much either, I always ended up with a bunch of debris in the center console. At least now it is clean and organized.
W8TUZ
Logan, Ohio
I can't bring myself to drill through the skin of a vehicle, although I agree that it would not be noticeable. Another installer did a great job doing just that, but I'm chicken I guess.
tmfok7
Far Eastern Washington...
Wow! Nice job! You basically did what I want to do with mine, eventually, but I'm gonna wait till I get a new vehicle. Thanks for the pics! They just give me more ideas to play with when I get to mine..... My one big wish though, is that Uniden would make the 15 or 996 with a removable remote mount head like what we have with amatuer radios now!
nexus
Mississippi
GREAT INSTALL... Glad you posted it too, because seeing the pictures shows me what mine would look like. I happen to drive an impala with the center console and like you have been fighting with where to mount my radios. I had considered the pedestal at one time. Well I have the BCD396 but I'm attaching it to an RH-96 and I have the Yaesu FT8900r which looks just like your 8800. And I also happen to have an XM tuner. So you essentially have pretty much the same components I'd have on one of those things. I must say I like the look.
And yes, replace those adapters for a single L-shaped BNC connector on your coax. You'll actually gain some room, a cleaner install, and less loss. I didn't see the picture of the shack though. I guess that one didn't go through. IC756PRO and an AL811 nice.
