2020 Chevy Silverado install
Matt when you get those in I'd like to see a SWR curve for like 146, 147MHz or so just out of curiosity if possible.
I will.
I just received two EMWave 1/4 wave VHF whips I'm trying out. I put them on the analyzer yesterday but didn't save the traces. I'll try to do that tomorrow. The EM Wave with the spring at the base looked really good. Less than 2.0:1 SWR across the VHF spectrum from 144 to 174MHz. Nice flat low SWR right in the middle. I'm going to try it out for a few weeks after using Larsen antennas for 30 years. They are a bit more expensive, so we'll see. I'll probably stick with the Larsen antennas at work based on past performance and price.
Plus, the all black EM Wave antenna looked really good on the roof of my wife's dark cherry red truck.
tweiss3
Is it time for Coffee?
Ohio
It looks like I will be using this write up this year when my truck is replaced with a 2021, though I don't think I will have the center console. The power will be very easy to run as you have shown.
ladn
Other option, if you want to go nuts, is get a 0.750" chassis punch. You can get them from places like McMaster-Carr and they do a really nice job.
I've used the chassis punch when doing trunk lid mounts. Worked great. I think mine is a Greenlee brand.. It also worked well when I've had to make up some "pie tin" temporary mounts.
slowmover
Fort Worth
Greenlee #730 Radio Chassis Punch
(various sizes)
FYI, these are an exact-size cut. More ordinary punches are oversized slightly.
Found the two I wanted (used) on eBay.
Google for, “instructions/how to sharpen”, sheet originally enclosed.
Pilot hole required. Access to both sides of the panel also required for procedure.
