30.1000 CSQ, slightly off frequency, with someone speaking Russian.
| 30.1000 | 418 | FM | 36 | 10/16/25 20:34:10 | 10/16/25 20:34:10 | LB | Other |
Could be Russian military, maybe Asian fisheries radio…least likely is Russian land mobile (business radio, etc.).
Russian taxis - using CB-type equipment - are all over the [roughly] 25.6 MHz - 30.2 MHz band, nearly all using narrow FM, 5 kHz spacing. 30.105 MHz is a known Russian taxi cab company frequency. Of course, Russian military comms also make sense (yes, they do use carrier squelch / CSQ).
European based DXers have monitored Russian comms on frequencies like 30.48125 MHz FM and 30.5925 MHz FM so 30.100 (ish) is not out of the question. For example, 30.4975 MHz falls within the same band plan as 30.5925 MHz. That, or somebody was just, well, off-frequency. 30.095, 30.100 and 30.105 are all possible taxi cab frequencies.
Officially anyway, low band for land mobile purposes is 33.000 MHz - 48.500 MHz and 57.000 MHz - 57.500 MHz using a mixture of 50 kHz, 25 kHz steps and 12.5 kHz spacing. The 30-33 band is very much a “free for all” and has military and civilian users mixed together with all kinds of band plans.
If you heard other Asian fishery chatter that would be my bet, I heard them yakking away (all in FM mode, all carrier squelch - CSQ) on 28.1125 MHz, 28.875 MHz, 28.9625 MHz, 29.000 MHz, 29.29.375 MHz, 29.400 MHz, 29.4125 MHz 29.425 MHz, 29.4375 MHz, 29.500 MHz, 29.525 MHz, 29.600 MHz, 29.6125 MHz, 29.625 MHz, 29.6375 MHz, 29.6875 MHz and 29.700 MHz (and those are just the within-10-meters frequencies) over the past 3-4 days during the short gray line propagation time frame.
30.100 MHz was/is also very active when the frequencies listed above were coming in. Of course the usual suspects on 27.5375, 27.675, 27.750, 27.775, 27.850, 27.875, 27.900, 27.925, 27.9375, 27.950, 27.9625, 27.975, 29.775, 29.825, 29.875, 29.9125, 29.925, 29.9625, 29.975, 30.000, 30.025, 30.125, 30.175, 30.1875, 30.225, 30.300, 30.4375, 30.475, 30.500, 30.550, 30.5625, 30.575, 30.600, 30.625, 30.700, 30.7125, 30.725, 30.750, 30.775, 30.800, 30.8125, 30.850, 30.900, 30.9375, 30.950, 30.975, 31.000, 31.025, 31.100, 31.200, 31.225, 31.625, 31.800, 32.000, 32.1125 and so on and so forth
