2025 VHF Low Band Logs
d119
Patch & Channels Clear...
EM1's guest house.
Today's captures from Southern California:
FrequencyToneCallsignUserConfirmed via
35.180179.9 (Not 156.7)WPZV709Comfort Engineering Tupelo, MSFreq/PL/Traffic
39.98088.5KGL481Greene Co, NC Fire/EMS 1Freq/PL/Traffic
37.380114.8VCZ479Donegan's Haulage Perth, ONFreq/PL/Traffic
31.480CarrierWQFS693Hanson Aggregates Woodburn, KYFreq/No PL/Traffic
37.440131.8(WQIZ284)(Paragon Concrete Waterford, MI)Freq/PL/Traffic
31.20091.5WQPM979Central HVAC Mountain Home, ARFreq/PL/Traffic
35.080118.8KSN800L&H Gyr Excavating Co Fon du Lac, WIFreq/PL/Traffic
37.100162.2KET358Morgantown, WV Utility BoardFreq/PL/Traffic (Beaconing CWID)
31.640118.8KFG780Havin Materials Union, MOFreq/PL/Traffic (Expired license)
35.060136.5KCD451Trudeau Sand & Gravel Saranac Lake, NYFreq/PL/Traffic
35.16082.5WQHV986Utility Lines Const. Svcs Anne Arundel, MDMale voice: "You off yet?"
35.960103.5WPEN207Vic's Towing Sonora, CANoisy/unreadable.
33.060123.0WQAH877Thomas Bus Service Burlington, WIFreq/PL/Traffic (both sides of conversation)
35.920141.3UnknownUnknownMale voice, unreadable.
37.700CarrierUnknownUnknownIntermittent dead carriers of varying signal strength.
35.740CarrierKLB621WL Roenigk, Inc. (Western PA)Freq/No PL/Traffic
35.040141.3KVW581Northern Clearing Ashland, WIFreq/PL/Traffic
37.020146.2KZM737W. Milford, NJ Police DispatchFreq/PL/Traffic (Fleetsync heard)
33.900136.5KGB393Radnor Twp, PA Fire DispatchFreq/PL/Traffic
33.980CarrierKGD259Warren Co, PA Fire DispatchFreq/No PL/Traffic
33.88082.5KQH904Licking Co, OH Fire F2Freq/PL/Traffic
33.86077.0KGC676Washington Co, MD Fire DispatchFreq/PL/Traffic
33.860179.9KCD346Tolland Co, CT Fire Ops NorthFreq/PL/Traffic
33.920CarrierWNKC982Lancaster Co, PA Fire DispatchFreq/No PL/Traffic
39.52079.7WQAW220Craig Co, VA Sheriff's DispatchFreq/PL/Traffic (MDC heard)
W1KNE
PITA from New England
New England
QTH: Bristol County, MA RX: BCD996P2 w/ Dipole
ProScan Logs (edited) - Note: Unattended monitoring. Based on PL decodes only. CSQ/Non decodes deleted.
FrequencyToneRSSIEnd Date / TimeSystem / SiteGroupChannelNumber Tag Tune
39.2200C 192.832511/18/25 14:50:31CHPLos AngelesWhite 3
39.3600C 162.232311/18/25 14:50:25CHPOrange CountyGreen B
39.4000C 186.232511/18/25 14:47:33CHPLos AngelesGold 2
39.8000C 162.236711/18/25 14:18:07CHPBorderTan B
39.2600C 118.831811/18/25 14:09:45CHPInlandCopper B
39.6800C 118.836811/18/25 14:08:41CHPInlandTurquois B
39.8800C 118.835711/18/25 14:08:22CHPInlandBeige B
42.4600C 167.945011/18/25 12:30:50CHPNorth DivisionBLK COA B
42.0800C 146.243911/18/25 12:28:56CHPFresnoSilver B
W1KNE
New England
I have 31.325 MHz 5 tones broadcast from the town next mine (500 meters) . It is road lights management (switch off/on) . I'm near Lyon - south east France . There are regular tones . There are also 31.3875 MHZ - 31.475 MHz -31.6875 MHz
These French signaling systems are very common to hear, here in New England. I get them often during this time of year.
marvinsuggs
Richmond, TX
Today’s Low Band Captures Richmond,TX Bearcat BCT15 X scanner Sirio GPA 27-45 MHz ground plane antenna, Butel ARC PRO software.
33.80 179.9 Quinebaugh Valley, CT FD
35.06 136.5 Trudeau Sand & Gravel, Saranac Lake, NY
35.78 107.2 Hubert Butler Construction, Portland, CT?
35.84 192.8 Bonded Concrete, West Sand Lake, NY
44.58 CSQ BNSF Hy-Rail limits compliance system
KF4ZTO
The "French Polytone" data link system is apparently officially called "EPAR". It's more or less a SCADA like system for street lighting (not traffic lights).
Frequencies (per my list)
31.3250 MHz
31.3875 MHz
31.4375 MHz
31.4625 MHz
31.4750 MHz
31.6875 MHz
31.9250 MHz
31.9750 MHz
I can confirm activity on all of the frequencies listed above, although, at least at my location, 31.325 and 31.6875 are, by a wide margin, the most commonly logged. Naturally, depending on which frequency step you're working with, 31.325 could be logged as 31.320 MHz [further confusing things is there is a POCSAG pager operating on 31.320 MHz somewhere in Europe] 31.6875 MHz could be logged as 31.690 MHz or 31.685 MHz, 31.4375 MHz could be logged as 31.435 MHz or 31.440 MHz and so on.
The EPAR network is a good band opening indicator, much like the French highway ePMR ("enhanced PMR") or "autoroute" VHF low band trunking radio network (officially it is named "DDE").
See here for a list of the DDE network's frequency plan (channel plan, including the repeater inputs - it uses a +4.4 MHz offset and 12.5 kHz spacing).
Repeater outputs:
35.0000 MHz to 36.2375 MHz (12.5 kHz spacing)
paired with
39.4000 MHz to 40.6375 MHz (12.5 kHz spacing)
The channel numbering is out of order, but the repeater input (39 MHz/40 MHz) is always +4.4 MHz higher than the repeater output (35 MHz/36 MHz)
d119
EM1's guest house.
39.480CarrierWPCC379County of Los Angeles, CAFreq/No PL/Traffic (EAS RWT)
33.740CarrierKYL829King William Co, VA Fire DispatchFreq/No PL/Traffic
35.740CarrierKLB621WL Roenigk, Inc (Western PA)Freq/No PL/Traffic
31.20091.5WQPM979Central HVAC Mountain Home, ARFreq/PL/Traffic (Both sides)
35.040141.3KVW581Northern Clearing Ashland, WIFreq/PL/Traffic (noisy)
33.980CarrierKGD259Warren Co, PA Fire DispatchFreq/PL/Traffic (brief)
33.88082.5KQH904Licking Co, OH Fire F2Freq/PL/Traffic ("Fire Control")
33.680CarrierKBH343Morgan Co, OH Fire DispatchFreq/No PL/Traffic (Paging test)
33.760151.4KEX264Imperial VFD Clinton, PA Freq/PL/Traffic
33.860146.2KBH343Morgan Co, OH Fire TacticalFreq/PL/Traffic (Callsign given)
33.720179.9WNHI321Lebanon, CT Fire OperationsFreq/PL/Traffic
d119
EM1's guest house.
35.080141.3UnknownUnknownMale voice giving directions.
39.84088.5KMK457Orange Co, CA WEROCFreq/PL/Traffic (These guys need to learn how to use their EAS equipment...)
37.700CarrierUnknownUnknownIntermittent dead carriers of varying signal strength. Weak today.
33.640114.8KNAW393Bourne, MA Fire DispatchFreq/PL/Traffic (TRS Patch)
35.720136.5WSDQ559Montauk Bus Service Suffolk, NYFreq/PL/Traffic
39.480CarrierWPCC379County of Los Angeles, CAFreq/No PL/Traffic (EAS RMT, no announcement).
33.900203.5UnknownUnknown"Car 15 copy direct, available". Is this Guernsey Co, OH? With that tone?
35.980146.2KNFU569Carroll Concrete Co, NH & VTFreq/PL/Traffic
31.200D432KBB436TB&H Concrete Washington Co, MDFreq/PL/Traffic (noisy)
33.840179.9WPDU424Mashantucket Pequot Tribal Fire DispatchFreq/PL/Traffic (LOUD today!)
33.78077.0KCE579SW NH Fire Mutual AidFreq/PL/Traffic
33.780114.8WQAX937Falmouth, MA Fire DispatchFreq/PL/Traffic (TRS Patch)
31.600100.0UnknownUnknownMale voice, southern accent: "copy that, thank you buddy."
Band was doing all kinds of weird stuff today. I've never heard Mashantucket Pequot fire that loud before, albeit it was a single transmission. Nothing out of Washington Co, MD Fire or Craig Co, VA.
That 33.900 203.5 has me curious. Guernsey Co, OH is listed as CSQ in the DB, and previous captures of Guernsey (confirmed) don't have a tone. So who is 203.5? WHICH ONE OF YOU WITH A "CAR 15" IS USIN' 203.5? Any ideas? :)
These SoCal agencies playing with EAS on Lowband really need some training. I'm curious to know who they are alerting down-stream, because they are putting out multiple tests per week (no-no), and Required Monthly Tests with no announcements. Orange County sent a required monthly test, then ended it, then made the announcement. That won't work, the message audio won't get relayed. LA County put an RMT out with no announcement at all. Orange County sent out over 5 Required Weekly Tests over the last two weeks. C'mon guys. @monitor142, any idea what these guys are doing with this stuff? It's somewhat dangerous actually... Especially if there are publicly accessible endpoints (AM/FM/TV) being alerted by the thing, and it's just dumping out crap left and right.
marvinsuggs
Richmond, TX
That’s what I have; 33.90 203.5 Guernsey Co, OH FD
KF4ZTO
I have
33.9000 MHz FM [CSQ] as Guernsey County, Ohio Fire
and
33.9000 MHz FM [203.5 Hz PL] as Guernsey County, Ohio Fire (old tone?)
Default or primary (active) log is that it is a CSQ / Carrier / No Tone system...that sometimes transmits a 203.5 Hz PL.
Chances are
-The system is actually carrier squelch (CSQ) but like other carrier squelch systems involving multiple transmitters, there may be one that transmits a tone anyway, for any number of reasons (eg. the system used to use that tone, but it no longer does...however, somebody forgot to reprogram a certain radio...or somebody programmed in that tone by mistake and just left it on because, the system being carrier squelch...it makes no difference to the end user if sometimes there is a 203.5 Hz tone and sometimes there is not.
It is interesting that you heard TB&H Concrete on 31.2000 MHz FM with 432 DCS / 432 DPL and they're located in Washington County, Maryland but you did not hear Washington County Maryland fire dispatch as well.
W8UU
Pilot of the Airwaves
Wellston OH
Are "Car 15" and "USIN" unit designators for Guernsey County on the CSQ system? If so, this is an easy match. If not - especially if the accent or time zone or the sound of the paging equipment is different - then you've got something new,
d119
EM1's guest house.
I have
and
Chances are
I noticed that as well. But TB&H was completely unreadable, so maybe I caught it on the tail end of the opening and Washington County never had a chance to make it through.
Yeah that must be it then. I'll update my logs to include Guernsey as 203.5. I realize a transmit tone means nothing to carrier squelch radios.
"USIN" was a colloquialism for "using". Car 15 is the only usable info I heard. Whatever it was, if it was actually on lowband and not a patch, it was voted and repeated.
kb3ouk
Harrisonville, Fulton County, PA
Washington County decommissioned 33.86 sometime Thursday 11/20, it has been replaced by a UHF paging system. That leaves Baltimore County as the last holdout on lowband in MD.
d119
EM1's guest house.
I was afraid that was also a possibility. Wow. That's a loss as it was a really good indicator of band status. I'm glad I got to be a part of that while it existed. That's a real bummer.
I don't think I've ever heard Baltimore County out here. Edit: Because I don't scan 46MHz. I added that just now. Still doubtful at that high a frequency though.
Speaking of out here, today's captures from Southern California:
39.84088.5KMK457Orange County, CA WEROCFreq/PL/Traffic (EAS Flash Flood Warning - Success!)
44.980146.2KGK672CHP Border Blue East BaseFreq/PL/Traffic (Dispatcher with stuck mic - hilarious)
35.080141.3UnknownUnknownMale voice "What you need there brother?"
44.300D116KMG580Vista Irrigation District Vista, CAFreq/PL (No voice, brief)
39.120136.5KNFM345State of Virginia - VDOCFreq/PL/Traffic (CWID)
33.760151.4KEX264Imperial VFD Clinton, PAFreq/PL/Traffic
35.980CarrierKLB621WL Roenigk, Inc. (Western PA)Freq/No PL/Traffic (both sides)
35.980146.2KNFU569Carroll Concrete Co NH & VTFreq/PL/Traffic (Expired license)
31.20091.5WQPM979Central HVAC Mountain Home, ARFreq/PL/Traffic (noisy)
35.720D156WQIG620AJ Myers & Sons Harmony, PAFreq/PL/Traffic
35.960103.5WPEN207Vic's Towing, Inc. Sonora, CAFreq/PL/Traffic
35.920D156WQIG620AJ Myers & Sons Harmony, PAFreq/PL/Traffic
35.800CarrierUnknownUnknownMale voice: "Pull out."
33.740CarrierKYL829King William Co, VA Fire DispatchFreq/No PL/Traffic ("King William")
Band was doing weird stuff again today. King William was unusually clear. Licking County was better than usual but faded off. Warren County had a stellar signal today. Sure wish I knew what they used for base radios and antennas. Audio quality is incredible and signal is generally LOUD.
Just lone Morgan County, OH (KBH343) on 33.860 today. ;(
marvinsuggs
Richmond, TX
31.82 D712 Educational Bus Transportation, Suffolk Co, NY
43.28 77.0 Ingram Readymix, Houston, TX
43.44 77.0 Ingram Readymix, Houston, TX
grosminet
Some made reference to eDMR . This is a french homemade DMR protocol with 3 slots . We have 2 main networks . One for EDF in 72 MHz in order to manage power electricty stations and the other for ex DDE name now DIR . French reseller is TPL . I asked to DSD developpement team to make a special version of DSD in order to decode eDMR, they refused . We have plenty of strong eDMR signals, one is 100 m from home.
KF4ZTO
Sorry to hear about 33.8600 MHz FM [77.0 Hz PL] Washington County Maryland Fire Dispatch Simulcast [KCG676] being taken off the air on November 20th, 2025 or 11/20/2025. UHF paging done on 453.6500 MHz NFM [77.0 Hz PL] under license WSHM697.
I just submitted the update to the RR DB page for Washington County, MD to indicate the same.
In regards to the DDE system, so that means it is now "DIR"? The term ePMR (vs. eDMR) is what I've seen thrown around. If the "DDE" 35 MHz system is now called "DIR" then I need to update things to reflect that - thank you for the update
King William is a powerhouse on 33.7400 MHz FM [CSQ] (even though they're operating on an expired license and the simulcast appears to be operated by a volunteer fire department instead of the county itself). I can hear it with a handheld receiver in Richmond, 35.5 miles straightline distance from the transmitter location. King William is doing 200 watts ERP from 37.53069 N / 76.79914 W.
KF4ZTO
Here's the King William transmitter antenna for 33.7400 MHz - KYL829. Per the license anyway, the transmitter power is listed as 100 watts, ERP is listed as 200 watts (maximum).
The antenna is located on top of the West Point (Virginia) town water tower.
Address on license:
329 6th Street
West Point, VA 23181
Transmitter control point is
West Point Virginia Town Hall
6th Street
The Google street view image of the water tower is showing an address of 320 6th Street West Point VA 23181.
The low band antenna looks to be a nice 1/4 wave ground plane or perhaps a folded dipole with a 4-radial ground plane setup... (middle antenna, if you look closely you can see the four ground plane radials).
Maybe something like this:
ANR 30-50 MHz Unity Gain Ground Plane Omni Antenna
marvinsuggs
Richmond, TX
Address on license:
329 6th Street
6th Street
Excellent information thanks for sharing. Do you mind if I posted this on my Facebook group?
