40 watt CB SWR Testing.
rescue161
KE4FHH
Hubert, NC
100. If you transmit 40 Watts and your meter is set to 10, the needle will ping out. Set it for higher than your max TX power.
prcguy
What model meter? If a radio can put out 40 watts with peak modulation it should be right around 10 watts dead carrier no modulation. Unless its a dual needle meter that reads out SWR where the meters cross you should have to cal the meter for SWR and I wouldn't think a power scale would matter for SWR in that case.
alcahuete
Antelope Acres, California
This was already answered for you in your other thread on the exact same thing.
