My location is about 5 miles from Manhattan. Signal is almost below the noise here and practically unreadable. I cannot make out enough to report the nature of the transmissions. Has anyone else logged this? Possible bootleggers?
Sorry - I'm to the west and south, between Hoboken and Staten island. Logged them around 7:15 this morning. Silent now.Which direction?
Usually this is a Telem channel for the FAA at airports, is it voice or Telem you are hearing ?My location is about 5 miles from Manhattan. Signal is almost below the noise here and practically unreadable. I cannot make out enough to report the nature of the transmissions. Has anyone else logged this? Possible bootleggers?
I'm hearing voice transmissions, but very weak and barely intelligible. Using a Uniden 536HP. No action on this freq today, but I have logged comms here on at least three occasions, same 151.4 tone, and always very early in the morning, around 7:00 - 8:00. With all of the construction sites around here, it's possible it is a bootlegger using an Asia FRS radio.Usually this is a Telem channel for the FAA at airports, is it voice or Telem you are hearing ?
Other than the FAA, it has also been found (documents) to be the Asia FRS Ch.05 at 500mw
and many a scanner user finding it an image, which make/model radio ?
or, don't rule it out, an image.I'm hearing voice transmissions, but very weak and barely intelligible. Using a Uniden 536HP. No action on this freq today, but I have logged comms here on at least three occasions, same 151.4 tone, and always very early in the morning, around 7:00 - 8:00. With all of the construction sites around here, it's possible it is a bootlegger using an Asia FRS radio.
I live in RF alley, 5 miles and line of sight to Manhattan. Images are always a possibility. You should hear the crud I pick up on 300 - 380 MHz on my 996T.or, don't rule it out, an image.
Anyone more familiar with the IF Freqs on the 536HP to suggest a potential target freq?
Also, not a known CCR default either
CCR Default Frequencies - The RadioReference Wiki
wiki.radioreference.com
reminds me of chasing my tail on a 35 mhz DPL signal, and the only licensed user was a PD who was PL 40 mi away.I live in RF alley, 5 miles and line of sight to Manhattan. Images are always a possibility. You should hear the crud I pick up on 300 - 380 MHz on my 996T.
Wow! An all too familiar story. Outdoor antennas are just about a no-go here with my scanners. They overload and desense.reminds me of chasing my tail on a 35 mhz DPL signal, and the only licensed user was a PD who was PL 40 mi away.
6-8 mo's later discovered it was my local DPW from their 460 repeater
mine was not even an outside antennaWow! An all too familiar story. Outdoor antennas are just about a no-go here with my scanners. They overload and desense.
Same here. All of my scanner antennas are in the attic, wood/shingle house, about 50ft asl.mine was not even an outside antenna
Keep hunting
