ProScan: 436HP setting in Proscan i.e. 'Download From Scanner'/'Upload To Scanner'
Chris0516
Pittsboro, North Carolina
Bob, The 325p2 has the 'Download From Scanner' and 'Upload To Scanner'. But the 436HP doesn't have those. I have been pouring through the manual, but I can't find how to do it on the 436.
ProScan
Software Provider
Ontario, Calif.
It's a different method on the x36HP and SDSx00 scanners. Click the Favorites Editor checkbox. It's located in the main menu on the far left side. After you open or create a new favorites list, then you can read from the scanner and write to the scanner. The scanner needs to be in Mass Storage mode for the read and write operations.
Whiskey3JMC
Airwave surfer...Cowabunga!
Philly burbs 🇺🇸
Firstly in Proscan you need to change your scanner type to BCD436HP (1)
Place a check by Favorites editor (2)
Create a new favorites list then you'll see Scanner Read & Scanner Write appear here (3)
