536 base unit questions
WILSON43
Northern New Jersey
I am using my 536 as a base unit and I have it sitting on a shelf . Unfortunately, as this
Unit does not have any rubber feet, etc., on the bottom it slides all over the place when
I use the various buttons and knobs.
Just wanted to pick brains here as to others are do resolve this problem. Any home
Brewed remedies?
Thanks in advance.
Dan
NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
Dyer, IN
In the past, I've screwed the mounting bracket into a short piece of 2x4, then put the scanner into the bracket. A piece of no-slip drawer liner on the bottom of the 2x4 to keep it from moving around and I was good to go.
Nowadays I use a three scanner desk holder for my mobiles as base radios.
WILSON43
Northern New Jersey
Thanks for the input. I found the little rubber feet, problem solved. Now I have to buy an external speaker since the one on the scanner faces DOWN!!!!
ofd8001
Louisville, KY
I got the feet on my mobile bracket to which the scanner is attached and canted upwards. I'm getting decent sound out of the bottom.
I know some folks have turned the scanner upside-down so the speaker is facing up, then set the display to upside down so it can be easily seen.
